roelof's avatar
roelof
5 years ago
Cyclone V HPS Baremetal Watchdog Error
I Am trying to get the Watchdog to generate a warm reset on my HPS Baremetal Application. My Setup: Cyclone V custom board Boot setup; BootRom -> Preloader -> HPS baremetal Preloader and HPS ...
  • Hi,
    May I know the Quartus version that you are using?
    How did you compile the preloader? Is it using the bsp-editor?
    Regarding the reset issue, could you check below documentation since you are using Cyclone V SoC and QSPI to boot if the issue that you are seeing related, and that you may try the solutions mentioned:
    https://rocketboards.org/foswiki/Documentation/SocBoardQspiBoot
