Cyclone V GX Transceiver - vanilla LVDS RX
As I understand it, you would like to configure the CV transceiver to run at 1.04Gbps with SERDES factor of 16. For your information, you can use the Native PHY IP to configure the CV transceiver. As I checked using the Native PHY IP, there should be no issue to achieve your target configuration.
For your information, there seems to be no specific example design per your target configuration. I have sent you a simulation example previous from wiki to your email for reference. This example is showing a CV Native PHY running with bitslip mode. You refer to the example on the modules required and interconnection between them. Hopefully it helps a quicker start.
Can you please resend the example transceiver RX project? Your first email did not have an attachment. Thanks!
- CheepinC_altera5 years ago
Sorry as I might have overlooked the email notification from your previous post. I have tried posting the design here to see if it can get through.
