13 years agoCyclone V GX evaluation kit question
Hi, I want to use the Cyclone V GX PCIe evaluation kit (http://www.altera.com/products/devkits/altera/kit-cyclone-v-gx.html). I need to design a daughter board that will connect to the FPGA via th...
13 years ago --- Quote Start --- Thank you for pointing that out. Indeed that means that I don't need voltage translator. My signals are going to be "well-behaved". I think that in this case a voltage translator might do more damage then good. For example it can limit the signals frequency or cause some kind of signal integrity problem. I just need to check that the other side can use 2.5V instead of 3.3V though I'm pretty sure it will be fine. --- Quote End --- If you don't use a buffer, then still try to be conservative; add series resistors on each of the signals that go between your board and the FPGA. Stuff them with a low-value (eg., 0-ohms or 10-ohms). You can use these as source terminations on signals configured to drive from your board over to the FPGA board. That'll eliminate ringing/overshoot. Cheers, Dave
