Cyclone V GX, Custom PHY, using fPLL as TX PLL
- 5 years ago
Okay, I have a valid PLL configuration now: two fPLLs that feed as external PLLs into three transceivers each.
For reference: the fPLL's output port is not valid as an input clock for a transceiver block if reconfiguration is enabled, because that routes the clock through the per-output C divider to allow reconfiguration to set up a divisor here, this gives an error message that the CLKCDRLOC port on the transceiver is not properly connected. The knowledge base entry for this is incomplete: connecting to outclk_0 only works if PLL reconfiguration is disabled.
The solution here is to disable reconfiguration for the fPLLs, or enable access to the DPA outputs in the PLL configuration and connect the clock to phout[0], then the design compiles.
HI Simon,
Pls see my comment below.
I'm trying to get six independent SATA links on a Cyclone V GX with six
transceivers, as far as I can see this should be possible.
- I am sorry to say but likely it's impossible to fit 6 duplex channel into 6 transceiver channel as CMU PLL itself will consume one of the RX channel
- You are going to need bigger FPGA device with more transceiver channel
- Rx channel can only be used either as Rx channel CDR or as CMU PLL
- Can I specify that with the Custom PHY megafunction, or do I need to
go a different path here? Simply configuring a Custom PHY in duplex mode
instantiates one CDR and one CMU PLL per channel, and these fail to
merge afterwards.
- CustomPHY IP required to use CMU PLL instead of fPLL for clocking Tx channel. So, you can't use fPLL. You need to use CMU PLL instead
- Can I use a single fPLL for all channels, or should I use both (one
for channel 0-2, one for channel 3-5)?
- You need to use CMU PLL since you are using CustomPHY IP
- If I want to support both 1.5Gbps and 3Gbps, can I divide the serial
clock in the channel, or do I need to set up a separate fPLL and set up
clock distribution accordingly?
- You need to use 2 PLL
- Can I run the fPLL off the system clock for the rest of the fabric
(generated in a normal PLL), or should I add a separate reference clock
to my board?
- Sorry, I don't quite understand your question here. Can you elaborate further ?
dlim
okay, I'm still trying to wrap my head around this.
Table 2-4 in CV-53002 mentions an x1_fPLL line that goes to three channels each (so I'd have to run both fPLLs with identical settings), and table 2-6 mentions a path for bonded configurations
fPLL » x1_fPLL » central clock divider » x6 » individual clock divider » serializer
Both of these sound like I can feed the x1_fPLL line directly into the channel divider, which would free the channel PLL for CDR. Since I don't need bonding mode, I can skip the step where the divider output is then fed back into the x6 network. Each group of three is then limited by the slowest device, but that is probably not a problem in practice.
I can see that this isn't possible with the Custom PHY, would it help to switch to Native PHY?
Regarding the clock source for the fPLL, table 2-1 answers my question -- the routing I had in mind would be very jittery, so I'll feed in a high-speed clock via GXB_REFCLK.
Simon
- SimonRichter5 years ago
