Cyclone V Features
Hi everyone,
I have a question regarding which of the Cyclone V family would be more suited for the application we are going to develop.
First of all, I have never used Intel FPGAs so excuse me if the questions sound a bit dumb.
Our system would require to receive some data from Ethernet or USB and drive some digital output or read some digital input and send back data to USB or Ethernet.
The question is: is required/recommended the Soc versions of the Cyclone V or should I be fine whitout?
Moreover, could I use the Lite version of Quartus Prime for the whole design? (purchasing only the IP Base Suite License)
Thanks in advance.
Hi Steve,
The Cyclone V SoC come with embedded linux repository. You can use the Eth and USB functions using command lines. All built-in IP like Eth and USB are functional well, but this is okay for development environment.
If you targeting end user application, then you will need SoC-EDS to develop the application software for users to use or control the eth and USB functions.
regards,
Farabi
- Farabi_Altera
Hi Steve,
regards,
Farabi - Farabi_Altera
For Ethernet and USB I would suggest to use Cyclone V SoC version. It has the IP built-in with the Arm Cortex A-9 SoC.
can refer here :
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-v/cv_54001.pdf
device overview for CV variants:
regards,
Farabi- steve_Alten
Thanks for the reply.
I have one more question. I have worked with Xilinx FPGAs and softwares before so I think I didn't understand exactly how to properly use the Intel tools.
We are probably going to use the MARS MA3 SoC Module for our application. If I got it right we can avoid purchase the standard version of Quartus and use the Lite version, and when the design is done we would need to purchase the IP Base Suite License to generate unlimited time files. But which software do I need to use to interface with the HPS part?
I've seen that there is the Nios II software. Is it included in Quartus Prime Lite version? or should I use other tools not included in Quartus Lite for my design?
- Farabi_Altera
Good choice! If you want to use Cyclone V SoC (MARS MA3 SoC module), you can use Quartus Lite for FPGA content development, the only thing you need to know is, for software development side, on ARM based linux application, you will need to purchase the SoC EDS tool. link: https://www.intel.com/content/www/us/en/software/programmable/soc-eds/overview.html
NIOS II SDK can be used for free. It is used for developing application software for NIOS II softcore processor inside the FPGA.
regards,
Farabi
