8 years agoCyclone V E Development Kit failed on Active Serial Configuration via JTAG
Hi All, I am currently working on Cyclone V E Development Kit. I tried to save configuration file into EPCQ256SI16N. I did follow the youtube https://www.youtube.com/watch?v=dpsfcgnqocu to gener...
8 years ago --- Quote Start --- Using dev kit, just refer to the given user guide and manual and schematic you will be fine. Do not go and look for Cyclone V handbook, it makes you confuse. https://alteraforum.com/forum/attachment.php?attachmentid=14417&stc=1 Resistor rework means, please go and find 1k resistor and put to them connected to Vccpgm. Since you are beginner, use the 1111 and bypass Max V configuration. Best Regards, Tzi Khang, Lim (This message was posted on behalf of Intel Corporation) --- Quote End --- I don't understand "please go and find 1k resistor and put to them connected to Vccpgm". What do you mean about it? Does it mean that I just need to change the Sw1 combination. I have tried combination "1111", but it doesn't work. Is there any other thing I missing in configuration process? If you are successful to program it, what MSEL combination did you use?
