12 years agoCyclone V E active serial load from N25Q00 QUAD SPI FLASH
Hi All, I'm trying to use Micron N25Q00 1Gbit serial QUAD SPI FLASH to load Cyclone V E (A7) using active serial interface. I currently have boards that have Cyclone V 5CEFA7U19C8 and are l...
12 years ago --- Quote Start --- Any other idea to try? --- Quote End --- How about tracing the SPI flash sequence? The only thing I can guess is that perhaps your 1G flash is not responding correctly, eg., perhaps your NIOS II software is in fact "smarter" than the Cyclone V configuration manager, in that you are using 4-byte addressing when programming and reading, but the Cyclone V is not, and its only issuing 3-byte addresses ... Do you have a logic analyzer, or another FPGA board that you can instantiate a SignalTap II instance, and the skill to solder some wires onto the SPI flash pins (unless of course you have a 10-pin AS header you can use directly)? That would be what I'd try next ... Cheers, Dave
