13 years agoCyclone V differential HSSI REFCLK implementation
I am trying to use a differential clock input of REFCLK pins for an HSSI interface on a Cyclone V FPGA. I have tried passing the differential clock inputs through an ALTIOBUF to get a single ended clock to use to clock the data from the transceiver Phy, but I get the following errors: Error (177035): The input pin adc_dco_p[0] assigned to HSSI Pin_AA11 has no fanout. Error (177035): The input pin adc_dco_n[0] assigned to HSSI Pin_AB10 has no fanout. Info (171121): Fitter preparation operations ending: elapsed time is 00:00:46 Warning (171167): Found invalid Fitter assignments. See the Ignored Assignments panel in the Fitter Compilation Report for more information. Error (171000): Can't fit design in device Here is the VHDL code for the ALTIOBUF: altiobuf_adc_dco : altiobuf_1 PORT map ( datain => adc_dco_p, datain_b => adc_dco_n, dataout => adc_dco ); I am trying to use the adc_dco output to clock a register or I would like to input the differential clock to a PLL. What is the correct way to implement the differential clock inputs to HSSI REFCLK pins to use for clocking the transceiver phy data? Thanks.3 Replies
By connecting the positive or non-negated clock input to the transceiver phy rx_cdr_refclk and reconfiguration_controller mgmt_clk_clk, I was able to eliminate the no fanout error for the adc_dco_p pin. Now i get the same error for the adc_dco_n pin. I have tried eliminating the pin and connecting it to a separate pll, phy, and reconfig controller, but still get errors. What do you do with the negated pin of the differential pair connected to differential HSSI REFCLK inputs?
Thanks. --- Quote Start --- I tried your suggestion and removed the ALTIOBUF and directly used the refclk non-inverted pin, but I still get the same error. Error (177035): The input pin adc_dco_p assigned to HSSI Pin_AA11 has no fanout. I found the following information at quartushelp.altera.com: <direction> pin <name> assigned to hssi <name> has no <fanin_or_fanout>. (ID: 177035) CAUSE: The specified pin is assigned to an HSSI input/output and has no fan-out (http://www.alteraforum.com/reference/glossary/def_fan.htm) and fan-in. HSSI input/output must be connected with exception of reserved refclk pins. ACTION: Remove the specified pin, location assignment, or both. Or if it is refclk, set as reserved How do I set the refclk pins to reserved? Thanks. --- Quote End --- - Altera_Forum
Error (177035): The input pin adc_dco_p assigned to HSSI Pin_AA11 has no fanout. I found the following information at quartushelp.altera.com: [h=3]<direction> pin <name> assigned to HSSI <name> has no <fanin_or_fanout>.[/h] (ID: 177035) CAUSE: The specified pin is assigned to an HSSI input/output and has no fan-out (http://www.alteraforum.com/reference/glossary/def_fan.htm) and fan-in. HSSI input/output must be connected with exception of reserved refclk pins. ACTION: Remove the specified pin, location assignment, or both. Or if it is refclk, set as reserved How do I set the refclk pins to reserved? Thanks. --- Quote Start --- You don't need altiobuf, and I guess, it doesn't work for dedicated clock signals at all. Just assign the non-inverted input pin and specify a differential IO-standard supported by the pins. --- Quote End --- - Altera_Forum
