13 years agoCyclone V differential HSSI REFCLK implementation
Hello, I am trying to use a differential clock input of REFCLK pins for an HSSI interface on a Cyclone V FPGA. I have tried passing the differential clock inputs through an ALTIOBUF to get a s...
13 years agoI tried your suggestion and removed the ALTIOBUF and directly used the refclk non-inverted pin, but I still get the same error.
Error (177035): The input pin adc_dco_p assigned to HSSI Pin_AA11 has no fanout. I found the following information at quartushelp.altera.com: [h=3]<direction> pin <name> assigned to HSSI <name> has no <fanin_or_fanout>.[/h] (ID: 177035) CAUSE: The specified pin is assigned to an HSSI input/output and has no fan-out (http://www.alteraforum.com/reference/glossary/def_fan.htm) and fan-in. HSSI input/output must be connected with exception of reserved refclk pins. ACTION: Remove the specified pin, location assignment, or both. Or if it is refclk, set as reserved How do I set the refclk pins to reserved? Thanks. --- Quote Start --- You don't need altiobuf, and I guess, it doesn't work for dedicated clock signals at all. Just assign the non-inverted input pin and specify a differential IO-standard supported by the pins. --- Quote End ---
