Cyclone V custom board VCCIO puzzling behavior
- 1 year ago
There are new measured data.
If I attached a simple 10k resistor to the 1.2V rail. it will drop back to normal 1.2 range.
But the loaded /w 10k is still measuring 40mV higher than unloaded DCDC w/o the FPGA chip.
So there are some leakage current inside the diode path? from VCCPD to VCCIO?
1- You observed voltage increase at VCCIO power rails. How about the IO signals within the impacted VCCIO banks? Do you observed voltage increase as well?
2- Do this observation impacted any functional behavior of the device? like design failure, FPGA temperature increase etc?
regards,
Farabi
1) yes both VCCIO and the FPGA-IO on the victim banks. However the VCCIO is higher than IO about 20-40mV.
2) Design failure <- not fully understand, temperature increase (cannot tells because w/o HPS running the system total power is less than 1.3W)
If needed can run a IR image to check hot spot but don't think this is helpful due to ~100mA on 12V input.
The design had individual power rail voltage+current sense yet minimum current range is ~=0.217 mA .
1mA is measured and print on linux hwmon, not sure this is out of range. (no extra load resistor is added as well)
Extra info:
Currently the DCDC is set to 1.8V no extra resistor or load show no issue.
So it is happened on 1.5V or below VCCIO standard.
