10 years agoCyclone V ALTLVDS_TX: MSB inversion and timing constraints
Hello everyone, I'm designing a board with a Cyclone V driving a DAC running at 420MS/s using a parallel DDR interface. To achieve this datarate (840Mb/s per stream), there is an ALTLVDS_TX com...
10 years agoHi kaz,
thanks for your response. The original constraint assigned by the MegaWizard for the SERDES was setup 3 and hold 3, is the hold multicycle supposed to be always one less than setup (for usual register-register transfers)? set_output_delay should not be necessary as far as I know, since I'm using dedicated hardware which reports a TCCS of 250ps, which is fine for my board and DAC. Nobody asked me to invert the MSB, I figured it out when looking at the signals with a scope. I guess I wasn't clear about that: The inversion is for the first bit in every serial word, not the MSB of the DAC. So if my parallel input for one stream looks like 0101, the serial bits transmitted are actually 1101. This holds for every transmit LVDS pair. Strange enough, the receiver (ALTLVDS_RX) does not show this behaviour. Regards, Philipp
