12 years agoCyclone V A7 problem downloading ELF to Nios in SBT
I have a 5CEFA7F31C6N design. I have it built and complied in Quartus and can load the SOF with a USB Blaster from either the Quartus programmer or from inside SBT Eclipse tools.. but I cannot get ...
12 years agoFirst of all. ¿do you add the system ID component in the SOPC Builder or Qsys Editor? When you add a nios processor you have to check the "cpu id" option. You can locate it in some folder of nios ii component. In my experience you can't get a good communication between nios system and the eclipse ide, if you don't check this option.
Don't forget, in the nios eds ide, to regenerate the bsp for your system, and the try to download the elf file. ( Ignore the timestamp mismatch during communication ).
