15 years agoCyclone reset/POR
Hi, I'm using the cyclone EP1C6 device. Just to make sure - which pin can be used as the reset state monitoring pin, meaning that in the VHDL code I can write (for example): if (reset = '0') the...
15 years agoI do have an external reset option on the DEV_CLRN pin. So how can I monitor the reset state in the code? Which external pin can be used for that? Or is there a special internal function for that?
