15 years agoCyclone reset/POR
Hi, I'm using the cyclone EP1C6 device. Just to make sure - which pin can be used as the reset state monitoring pin, meaning that in the VHDL code I can write (for example): if (reset = '0') the...
15 years agoHi FvM,
thanks for the reply. I'm not a VHDL expert but when I write the code I usually write something like: if reset = '0' then ... ... ... elsif rising_edge(clk) then ... ... ... If I understand correctly you're saying that there is no need for the first "if" so I should initialize all the values in the object declaration section and in the code itself just start from the "if rising_edge(clk)..." part?
