16 years agoCyclone LUT Performance
Hey, How can I get LUT performances in various Altera FPGAs, or specifically at Cyclone 3? Thanks
16 years ago --- Quote Start --- First thing first, Thank you for the help. Now, My goal isn't to check how fast my design should work, but to plan my algorithms so they will be able to work at certain frequency, while trying to work with maximum number of logic levels. If you got an idea how it could be made, I would be glad to hear. Thanks again for the help. --- Quote End --- Hi rishum, in my point of view there is no way to get your required information without a P&R run. Of coarse you can calculate the delay of nxLUT delay, but you don't know how your functions will be implemented. Are DSP blocks used? How is routing delay ? Which speed grade is used .... Kind regards GPK
