14 years agoCyclone IV vertical migration F484 1,0mm one size fits all
Edit: Issue has been solved, see my post with attachment down below. Hi, I was wondering, has anyone stumbled over a document describing a "one size fits all"-document for the vertical mig...
14 years agoIt shouldn't take but an hour or two to capture all the pin information in Excel to your liking and compile it together. I went through the exercise on the FG256 for the densities I was interested in for the CycIII and CycIV and noted the I/Os that were grounds in some packages, I/Os in others or similarly cross-functioned. You can glance at my Excel file at johnhandwork.com/Altera/EP3C4CEcommon.xlsx for ideas. I color coded based on VCC types and grounds where pns didn't match up and highlighted the pin names of those that didn't match between "adjacent" devices.
The amount of cells can give you an idea why there may be no clean way to communicate the info but you can get from here to there without great trouble. It's just inconvenient.
