12 years agoCyclone IV total embedded memory size
i am quite new to FPGA programming, and a bit confused about the range for on-chip memory. In my project i am using an Cyclone IV EP4CE10E22C8N board. I would like to know now how much memory i can assign in Qsys to my on-chip RAM module. The total memory size must be less tha the available in the target FPGA. From the cyclone IV dev handbook i know that the FPGA i use has 414 Kb organized in M9K memory blocks (so i have 46 M9K blocks) So i should be able to use slightly less for my RAM if the cpu takes some memory for itself as i read in http://www.alteraforum.com/forum/showthread.php?t=39788 In qsys my nios processor uses tweo m9k blocks. So i should be able to set up a system with about 45 KB. But compiling in Quartus i get the error message, that my design does not fit into the device, so i'm not sure how to calc the max usable memory size. Also i stumbled over the Mega Wizard Plugin Manager where i can setup my own blocks in quartus. When i want to create a RAM device there and increase the amount of 32 -bit words (as my nios cpu has a 32 bit data bus) i monitor that the resource usage contains for example 34 luts; 64 M9K blocks and 2 register. Now i dont really understand how many M9K blocks are there on the FPGA? Thanks a lot in advance for your answers! Cheers TimNo RepliesBe the first to reply
