CG7
3 years agoCyclone IV shortcircuit in VCCint causes
Hi, I've got a custom board with EP4CE6 on it, the board works but sometimes, it fails (defect seen on 6 boards). The fail seems to happen at startup. After inspection the power rail VCCint of the...
AqidAyman_Altera
3 years agoHello,
May I know what is failing during the startup? Can you elaborate more on this?
If possible, you can also share if there is any snapshot on the relevant issue that might help.
Thank you.
