14 years agoCyclone IV Programming
Hi I have a board with EP4CE622C8. I pull up CONF_DONE, nCONFIG and nSTATUS by 10K resisters. MSEL0,1,2 and nCE pins is connected to GND. According to datasheet Cyclone IV E , I connect Jtag to FP...
14 years agoIt doesn't do programming through Passive Serial or JTAG? If You're programming the FPGA using passive serial, then check if the data flow is correct.
