Cyclone IV PLL min input frequency
What is minimum input clock for Cyclone IV E PLL? Data sheet states that minimum Fin=5MHz, but PLL locks even to 500KHz input clock freqency. Can someone explain this to me? Thanks5 Replies
--- Quote Start --- I suggest you'll have to use an independent, fixed clock to measure the frequency of your changeable clock. This will allow you to determine whether the clock is above of below a threshold - say 10MHz. I suggest you keep the threshold well away from 5MHz. You can then have two separate (potentially identical) blocks of logic; one clocked directly from your varying clock; the other from your reconfigurable PLL. Depending on the clock frequency, you either use the result from one portion of logic or the other. Cheers, Alex --- Quote End --- Thanks for your suggestion. I am affraid that there is not enough FPGA memory resources to duplicate those blocks. I tried to bypass PLL output clock with dynamicaly controlled MUX, and providing direct clock to logic but no luck. Thanks again - Altera_Forum
Cheers, Alex - Altera_Forum
Thanks for your answers. Then could someone help with the solution on how to implement interface when FPGA is clocked in range of 100kHz - 200MHz, and clock can be changed while operating? I have implemented reconfigurable PLL to cover range 5MHz to 200MHz, but currently i dont have any ideas on what to do when FPGA is clocked below 5 MHz. - Altera_Forum
I second Alex's recomendation. You will find that as temperature changes and/or electrical noise is added or even changes your PLL won't lock reliably any more. We had one in our lab that was sometimes locking to a WiFi router that was nearby rather than the way out of spec input signal. "It works in the lab, why doesn't it work at the customer's site"?
As you've found, the spec states fIN(min)=5MHz. Don't rely on all devices operating correctly if you're operating them out of spec.
The only suggestion I have is that the PLL is locking to some harmonic content of your clock source. Cheers, Alex
