10 years agoCyclone IV PLL min input frequency
Hi, What is minimum input clock for Cyclone IV E PLL? Data sheet states that minimum Fin=5MHz, but PLL locks even to 500KHz input clock freqency. Can someone explain this to me? Thanks
10 years ago --- Quote Start --- I suggest you'll have to use an independent, fixed clock to measure the frequency of your changeable clock. This will allow you to determine whether the clock is above of below a threshold - say 10MHz. I suggest you keep the threshold well away from 5MHz. You can then have two separate (potentially identical) blocks of logic; one clocked directly from your varying clock; the other from your reconfigurable PLL. Depending on the clock frequency, you either use the result from one portion of logic or the other. Cheers, Alex --- Quote End --- Thanks for your suggestion. I am affraid that there is not enough FPGA memory resources to duplicate those blocks. I tried to bypass PLL output clock with dynamicaly controlled MUX, and providing direct clock to logic but no luck. Thanks again
