Cyclone IV PLL IP megawizard crash
- 2 years ago
I can confirm that PLL Megawizard is crashing in Quartus 23.1 when advancing to the Output Clock tab. I tried with Cyclone IV E and Cyclone 10 LP, just using default settings. Also a PLL component defined in Quartus 19.1 reopened in 23.1 crashed when selecting output clocks.
The problem has been already reported, see e.g.
https://community.intel.com/t5/Intel-Quartus-Prime-Software/Bug-in-Quartus-Prime-Lite-23-1-ALTPLL-MegaWizard/m-p/1554826
https://community.intel.com/t5/Intel-Quartus-Prime-Software/Quartus-Prime-Lite-23-1-PLL-Wizard-Problem/m-p/1572564
The first link however contains already a solution by copying 22.1 Megawizard files to 23.1 installation. I don't see known issues related to PLL Megawizard reported for Quartus-23.1std.0.991-windows in FPGA knowledgebase, shouldn't the problem appear there 2 month after first bug reports? At least the problem should be known internally to avoid misleading suggestions as above.
Definitely waiting for an official patch.
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
