14 years agoCyclone IV JTAG Working, Configuration Not
This is the first time I have had a design around an Altera part not load properly. I am sure it is my fault, but I am running out of things to check. This is with a Cyclone IV EP4CE10E22C8N. Both of...
13 years ago --- Quote Start --- As a side note, the M25P40 part from Micron/Numonyx is a drop-in replacement for an EPCS4 and supports 2.3V to 3.6V. --- Quote End --- No they don't go down to 2.3V (at least any of the device data sheets I've looked at). I was recently stumped with some recent experiments to prove an M25P16 was an acceptable replacement for a Spansion part that was going obsolete. After much hair pulling I realised I'd set the supply to the config prom wrongly, it was at ~2.2V. The Spansion part worked but the M25P16 didn't. The M25P data sheet said >2.7V, when I fixed the supply to 2.8V it worked finw. I'd be keen to find an EPCS16 substitute that works down to 2.5V, what parts were you looking at? Nial.
