14 years agoCyclone IV JTAG Working, Configuration Not
This is the first time I have had a design around an Altera part not load properly. I am sure it is my fault, but I am running out of things to check. This is with a Cyclone IV EP4CE10E22C8N. Both of...
13 years agoI guess no one has solved this yet...
I am currently running into the same issue. I get the "success" messages when programming the config PROM with a JIC file. I can also run a verify immediately after, and even see my device signal "CONFIG DONE". However, if I power cycle my device, I never see "CONFIG DONE", but I see a ton of traffic on the Serial interface between the CONFIG PROM and the FPGA. If I run a verify at this point, I get the Flash Error. Thoughts?
