14 years agocyclone IV I/O standard
Hi, I am using ep4ce30f29c6 (fbga780pin) with aproximately all IO in use. because of the need to use on chip termination, I use 3-volt as vccio. my main worry is that other parts in my design are ...
14 years agoClamp diodes are silicon diodes with respective forward voltage. Exact data can be e.g. derived from IBIS files. With 0.3 V forward voltage, diode current will be low. I think however, that reasonable source side impedance matching of fast digital signals to the FPGA can obviate the need for clamping diodes.
