16 years agoCyclone IV GX LVDS clock input resistor termination
Hi Altera experts, I am designing using the EP4CGX15BF14C8 (I have the transceiver dev board to try my design). Question I want a reference clock for the transceivers so I use a 125Mhz osc...
16 years agoYou need a termination resistor (see page 6-22 of the handbook):The LVDS standard does not require an input reference voltage, but it does require a
100- termination resistor between the two signals at the input buffer. An external resistor network is required on the transmitter side for the top and bottom I/O banks. page 6-28The LVDS receiver requires an external 100- termination resistor between the two signals at the input buffer. table 6-10 (volume 1) and table 1-5 (volume 2) VCC_CLKIN for LVDS = 2.5V Good luck, Ton
