silv0954
5 years agoCyclone IV EP4CE75F29I7N
I'm looking to see if there is a drop-in equivalent for this FPGA. For example, can the EP4CE115F29I7N be used as a circuit level equivalent? What type of configuration changes when programming mig...
NurAiman_M_Intel
5 years agoHi,
Kindly clarify what is mean by circuit level equivalent?
Aiman
- silv09545 years ago
Sure thing.
First off, is there a chip with the same pin-out as the EP4CE75F29I7N? For example, can I substitute the EP4CE115F29I7N on the PCB without having to reconfigure the rest of the PCB to account for different pin locations, etc.
Secondly, will I have to completely rewrite the HDL to account for the new chip? Or is it simpler than that; for example, just telling the compiler to use the EP4CE115F29I7N instead?
Thank you in advance!
Best,
Randy
