11 years agoCyclone IV EP4CE15 FPGA JTAG programming issue
Hello, I have USB Blaster Rev. C and I have ready made .Jic file only for my FPGA. (I have no other file except .Jic file) My FPGA chip is on the main board and also have a JTAG connector on ...
11 years agoAre you still having issues with this?
The .jic file you specify is only used to program an external configuration flash device attached to the FPGA. Do you have an EPCS (or similar) configuration device attached to your FPGA? As long as the .jic file has been generated for the right target FPGA, with a valid .sof file, the Quartus programmer should manage to program the configuration flash. Cheers, Alex
