8 years agoCyclone IV E, transferring data using serial port
Hello everyone, In a nutshell I have the following FPGA: http://fpga.redliquid.pl/images/ep4ce6/1.jpg (FPGA Cyclone IV E, ECP4E6), and what I want to do is to use the serial port. I've b...
8 years agoHi,
Go to project navigator -> Files ->select the required file(.qsys/.qip) ->right click and set as the top level entity. 1.If you qsys design is top then save the project and qsys design in the same name. 2.If you have to interface with own logic/top file than the top file and project name to be same and save the qsys design in some other name. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
