14 years agoCyclone IV E LVDS output voltage
Two questions:
1. According to Cyclone IV E handbook, the LVDS output level is 2.5V. So if a 3.3V is supplied to an I/O bank VCCIO, all the differential I/O pairs located in this bank can not configued as LVDS standard, is it right? 2. We have a fiber transmitter which is driven by differential PECL logic signals. From my understanding, the I/O pins of Cyclone IVE can not directly drive this transmitter. An extra chip is needed to convert a pin with LVTTLoutput (3.3V) or a pin pair with LVDS output to PECL standard. am I right? Thanks!3 Replies
The operation is beyond specifications and you can hardly expect a reliable statement about "always work". Maximum speed and voltage levels may be different.
Through testing, we find that FPGA can correctly output LVDS signals with 3.3V bank VCCIO input. The Cyclone IV E handbook requires that the pins can be configured as LVDS only with 2.5V bank VCCIO supply. I am not sure if the 3.3V LVDS can always work well. - Altera_Forum
Up to medium speeds, a pseudo-differential 3.3V ouput, level-matched by a resistor network may be an option.
