12 years agoCyclone IV AS and JTAG programming at different voltage levels
I have some questions regarding the programming of Cyclone IV devices as shown in figure 8-28 in the datasheet. In my case, the banks where all programming pins reside (1, 2, 5 and 6) are all 2.5V. ...
12 years ago1. You can get rid of the AS header and all related overvoltage problems by using indirect JTAG programming for the AS configuration device.
2. I prefer 3.3V supply and external schottky clamp diodes with series resistors for the JTAG header. It's quite clear that the 2.5V supply recommendation is a concession to overvoltage sensitivity and the fact, that some Altera programming adapters are driving the JTAG lines with rather low impedance and respective overshoot. --- Quote Start --- 3. The nCSO and ASDO pins are used for LVDS signals --- Quote End --- With connected AS flash? Doesn't sound like a good idea.
