11 years agoCyclone IV and M25P16 8 pins SPI Flash
Hello, I have a board with M25P16 8 pins SPI Flash on it. Now I want to program it with .jic in Active serial mode, for that I instantiated Altera Serial Flash Loader IP according to an37...
11 years ago --- Quote Start --- After configuring the Serial Flash Loader and adding .qip file should I need to add IOs in pin planner? How should i instantiate it in my top module? If it is possible for you to give me one simple design like 8-bit LED for .jic, I would be thankful. --- Quote End --- Your question does not make sense. If you have generated a .jic then you have already created a project. If you did not assign pins during the generation of that project, Quartus will randomly assign pins, and you could damage your board. Which Cyclone IV board do you have? If I have the same kit, I can point you to a 'basic' example. Quartus has several PDF tutorials linked from the Help menu. You should read those, and read the Quartus handbook (at least the sections on FPGA design). Cheers, Dave
