15 years agocyclone III vcca = 1.2v
because vcca connect 1.2v(must connect 2.5v) .jtag can't be successful;
I use EP3C16F484I7 ,package BGA , anybody can give me some advices ?4 Replies
i see;
i have to make a new pcb for this error; thanks for your help again; - Altera_Forum
The datasheet clearly specifies a VCCD_PLL voltage range. 2.5V must be expected to damage the chip, because it exceeds the absolute maximum rating of 1.8V.
thanks a lot;
if i force vcca and vccd to 2.5v.what will do? - Altera_Forum
You have to find a way to change the VCCA connection, otherwise the device is kept in reset. Without knowing your exact board layout, it's difficult to see if there's a possible workaround.
