19 years agoCyclone III Serial FlashLoader
I would like to design my Cyclone III board to use the "Serial FlashLoader" (with a JTAG connector and an serial config device).
The documentation claims you can do it but Quartus (v7.0) doesn't highlite the required megafunction when targeting a Cyclone III. Has anyone tried this and can verify that it works? Thanks, Rob Other Cyclone III config questions... 1) What's with the diodes and caps on page 10-80 ? 2) Just curious - why doesn't the Cyclone III support PS configuration from a config device?4 Replies
Hello Test_Bench;
Please refer to the document mentioned in the post by Joe D above. If after reading that, you still have questions post them here if you like. I believe everything you need to know is in that App Note. If it is not clear, that can be addressed as well. Avatar - Altera_Forum
Hi every body,
I want to know how I connect the JTAG to assure the Serial Flash Loader for a CYCLON III FPGA (EP3C25Q240). I know that I must use the SFL function and connect the M25P16 FLASH RAM like this : M25p16 EPCS16 C-----------DCLK D-----------ASDI Q-----------DATA S-----------NCS W-----------VCC (With pullup) HOLD-------VCC (With pullup) VCC--------VCC VSS--------GND But to program the FLASH via the JTAG ,I don’t know if there is a special connection between the CYCLON III and the M25P16 Thanks - Altera_Forum
Its called the serial flash loader in the megafuction list. See page 7 of AN 370.
http://www.altera.com/literature/an/an370.pdf I don't think it became available until 7.1 recently when Cyclone III device configuration first became available. - Altera_Forum
I believe this feature is available in version 7.1 of the tools.
Give that a try.
