15 years agoCyclone III, read write errors with True Dual Port M9K Memory
Hello Everyone, i am having some problems with using M9K block on Cyclone III, following is the detail of my system configuration, and the workout i have done till now and their results, if any on...
15 years agoThis is definitely a timing problem.
I think you are reading memory data before addr lines have set up (then you get data from a different address) or before data lines have set up. Have you tried to add wait states on memory access: usually this fixes the problem in such cases. Are you sure the data is written correctly into memory and the problem is on the read side? Regards
