15 years agoCyclone III pulse generator
Hello, I'm designing a PCB with a Cyclone III FPGA. Now I would like to have a few output (block) signals adjustable in frequency (100KHz - 1MHz), duty-cycle and phase. My questions: - C...
15 years agoHi Frans
--- Quote Start --- - Can I use every I/O pin on the FPGA? ( so I can order my PCB ) --- Quote End --- Yes. Provided the pin is a generic I/O and not a dedicated pin (i.e. jtag, config, ...). Quartus pin planner will guide you in connecting your signals to right pins. --- Quote Start --- - How should I program my FPGA? --- Quote End --- There are many configuring options. Usually you want to use jtag in debug phase and then a serial eprom when the board is deployed. Refer to the documentation of the device you want to use. --- Quote Start --- - Can I use the Altera Quartus II Web edition to program my FPGA? --- Quote End --- Sure. Unless you are planing to use a big high end device (and I don't think this is your case), you can use Quartus Web Ed. for the complete design flow, from scratch to release. Regarding your question about fpga programmable functions the answer is again yes. You can virtually program fpga for any function. The limit is your fantasy, besides device resources. The freq modulator and pwm you need is one of the basic function, very easy to implement. Regards Cris
