16 years agoCyclone III programming problem (JTAG and AS)
Hello All, Please help! We have a problem with Cyclone III devices programming. We are using the board with 5 Cyclone III devices, connected in Combining JTAG and Serial (ESPC64) configuration. Fi...
14 years agoHey DAVE,
I am still stuck with the same problem of getting my configuration data into the serial flash EPCS4. I read about getting this task done and found that for getting the configuration data into the EPCS the serial flash loader concept has to made use. but on the other hand i also read that for that the fpga has to be in AS mode so the MSEL(2-0) has to be changed from (000) to (101). that is from JTAG mode to AS mode. now if i set the mode to as then will the JTAG configuration scheme work. regards saurabh
