15 years agoCyclone III programming problem (JTAG and AS)
Hello All, Please help! We have a problem with Cyclone III devices programming. We are using the board with 5 Cyclone III devices, connected in Combining JTAG and Serial (ESPC64) configuration. Fi...
14 years ago --- Quote Start --- please can you elaborate a little more.. --- Quote End --- The JTAG TAP machine is on page 10 http://www.altera.com/literature/ug/ug_virtualjtag.pdf If you hold TMS high and clock TCK 5 times, then you will end up in the TAP reset state (TEST_LOGIC_RESET). The device IDCODE will be loaded into the DR register. If you clock in the TMS code 0, 1, 0, 0, you will be in the SHIFT_DR state. Hold TMS low and pulse TCK for 32 clocks and IDCODE will be shifted out on the TDO pin. Put the TAP back in reset, and repeat. You should then have a data stream on every TDO pin on your board. If you don't, then your JTAG chain is broken. Cheers, Dave
