17 years agoCyclone III power for VCCA
https://www.alteraforum.com/forum/attachment.php?attachmentid=1434 https://www.alteraforum.com/forum/attachment.php?attachmentid=1435 Hi Dear all friends hope to be fine I am using ep3c80...
17 years agoHi Frank and Thanks for your information
I attached my schematic here to see if I did ok with these VCCA pins or not actually for every VCCA pin I have two couple capacitors .1uF and 220pF. and for issolating analog power and ground I have two ferriet beads between and I have seperate ground islands. i am not sure that the way I used the ferriet bead for VCCA and 1.2V is ok or I need to change it I'm wondering if you can let me know thanks Regards
