16 years agoCyclone III pin assignment?????????
I am a beginner in this field of FPGA,
and I have to make a video converter (composite -> VGA) using CYCLONE III. I finished the development of all blocks in verilog and I still have the implementation of my code in that famous FPGA. my problem is the assignment of pins. I can not find the table showing the pin assignments of such audio or video codec decoder (for example).... can somebody help me please?4 Replies
In this case, u can use the user pins as output pins. See the list of user pins available and assign your outputs to those pins.
Cyclone® III FPGA base board
+ touch-panel LCD daughter card - Altera_Forum
--- Quote Start --- Hi, the required pin assignments depends on your board. E.g. you have to look which FPGA pins are connected to VGA connector. GPK --- Quote End --- ... then you open the Assignments->Pins Quartus menu and you'll find a table/fpga-layout where you can constrain each internal signal to connect to the proper pin. Regards Cris - Altera_Forum
--- Quote Start --- I am a beginner in this field of FPGA, and I have to make a video converter (composite -> VGA) using CYCLONE III. I finished the development of all blocks in verilog and I still have the implementation of my code in that famous FPGA. my problem is the assignment of pins. I can not find the table showing the pin assignments of such audio or video codec decoder (for example).... can somebody help me please? --- Quote End --- Hi, the required pin assignments depends on your board. E.g. you have to look which FPGA pins are connected to VGA connector. Kind regards GPK
