16 years agoCyclone III pin assignment?????????
I am a beginner in this field of FPGA, and I have to make a video converter (composite -> VGA) using CYCLONE III. I finished the development of all blocks in verilog and I still have the impleme...
16 years ago --- Quote Start --- Hi, the required pin assignments depends on your board. E.g. you have to look which FPGA pins are connected to VGA connector. GPK --- Quote End --- ... then you open the Assignments->Pins Quartus menu and you'll find a table/fpga-layout where you can constrain each internal signal to connect to the proper pin. Regards Cris
