17 years agocyclone iii nios boot from epcs
cyclone iii nios boot from epcs: i use nios_flash_programmer to burn fpga+nios to epcs64 ,but do not boot from epcs,i use memtes to Test EPCS Serial Flash first time : ------------...
17 years agookay thats it, you use quartus 9.0 without sp2
can't tell you right out of my head what was the exact bug, but there is a bug with this quartus version and epcs stuff. somebody mentioned at niosforum that mysupport said that this bug won't be fixed in sp1 but should be in sp2 and as long as there is no fix, users should unpack some files from quartus 8.1 unfortunately nobody said it is fixed in sp2, but i would install sp2 and give it a try. sorry i do not use quartus 9.0 due to this bug until somebody says it is solved. maybe you ?
