17 years agocyclone iii nios boot from epcs
cyclone iii nios boot from epcs: i use nios_flash_programmer to burn fpga+nios to epcs64 ,but do not boot from epcs,i use memtes to Test EPCS Serial Flash first time : ------------...
17 years agoThank you MSchmitt.
My fpga is ep3c25q240c8 My msel pins is 010 My epcs64 power is 3.3v fpga image is loaded from epcs after power on quartus 9.0 no sp This my Nios II IDE Flash Programmer # !/bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.# cd D:/FPGA/sopc_cy3/software/memtest_usb/Debug# Creating .flash file for the FPGA configuration "$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="D:/FPGA/sopc_cy3/chip_top.sof" - -output="chip_top.flash" Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=chip_ top.opt D:/FPGA/sopc_cy3/chip_top.sof chip_top.pof Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Peak virtual memory: 73 megabytes Info: Processing ended: Wed Sep 02 16:08:47 2009 Info: Elapsed time: 00:00:04 Info: Total CPU time (on all processors): 00:00:04 Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert chip_top.pof chip_top.rpd Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Peak virtual memory: 70 megabytes Info: Processing ended: Wed Sep 02 16:08:51 2009 Info: Elapsed time: 00:00:04 Info: Total CPU time (on all processors): 00:00:04# Programming flash with the FPGA configuration "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x0008a000 --sidp=0x0 0088030 --id=6395680 --timestamp=1251442455 --instance=0 "chip_top.flash" Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x00088030: verified : Checksumming existing contents 00000000 : Verifying existing contents 00010000 : Verifying existing contents 00020000 : Verifying existing contents 00030000 : Verifying existing contents 00000000 : Reading existing contents 00010000 : Reading existing contents 00020000 : Reading existing contents 00030000 : Reading existing contents Checksummed/read 12kB in 0.2s 00000000 ( 0%): Erasing 00010000 (25%): Erasing 00020000 (50%): Erasing 00030000 (75%): Erasing Erased 256kB in 2.3s (111.3kB/s) 00000000 ( 0%): Programming 00010000 (25%): Programming 00020000 (50%): Programming 00030000 (75%): Programming Programmed 245KB +11KB in 5.6s (45.7KB/s) Did not attempt to verify device contents Leaving target processor paused# Creating .flash file for the project "$SOPC_KIT_NIOS2/bin/elf2flash" --epcs --after="chip_top.flash" --input="memtest _usb.elf" --output="epcs_controller.flash"# Programming flash with the project "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x0008a000 --sidp=0x0 0088030 --id=6395680 --timestamp=1251442455 --instance=0 "epcs_controller.flash" Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x00088030: verified : Checksumming existing contents 00030000 : Verifying existing contents 00040000 : Verifying existing contents 00050000 : Verifying existing contents 00030000 : Reading existing contents 00040000 : Reading existing contents 00050000 : Reading existing contents Checksummed/read 110kB in 2.6s 00030000 ( 0%): Erasing 00040000 (33%): Erasing 00050000 (66%): Erasing Erased 192kB in 1.8s (106.6kB/s) 00030000 ( 0%): Programming 00040000 (33%): Programming 00050000 (66%): Programming Programmed 83KB +109KB in 4.0s (48.0KB/s) Did not attempt to verify device contents Leaving target processor paused
