14 years agoCyclone III Latch Not Latching
Hello all, I have a peculiar problem. I have been tasked with solving a problem that affects some of our production units but not others (even though the FPGA part number and configuration are ...
14 years ago --- Quote Start --- Would it be safe to say that it is caused by a glitch? --- Quote End --- In my view, a pure guess can't be "safe" because it possibly blinds out the actual reason. I don't see an option for glitch generation in the present test case, I think the possibility of a real interfering signal (crosstalk, ground bounce) should be considered. Depending on the required timing, changing the storage function implementation can reduce the interference susceptibility. Avoiding latches is a good idea in most cases.
