14 years agoCyclone III Latch Not Latching
Hello all, I have a peculiar problem. I have been tasked with solving a problem that affects some of our production units but not others (even though the FPGA part number and configuration are ...
14 years agoLatches are asynchronous things and hence tricky.
There might be a (even very) narrow glitch on the 'internal blue' signal that may not be seen at the corresponding pin. This however will reset the latch. Speed of the devices varies between batches and usually improves slightly as the manufacturer tunes the process continuously.
