19 years agoCyclone III FIFO problem
Hi, I have a problem with a Cyclone III design which uses two 512byte Fifos. The problem is that the design is working fine, and after changing sth. e.g. adding some signals to signal tab, t...
19 years ago --- Quote Start --- maybe because the timings for CYCIII in Quartus are preliminary (I use 7.1 SP1) --- Quote End --- I can't tell whether you're wondering if the timing is preliminary or if you already know it and just wonder if that's related to the problem. If the former, look for a Fitter compilation message like the one below, which I got with QII 7.1 SP1. Warning: Timing characteristics of device EP3C25E144C7 are preliminary
