19 years agoCyclone III FIFO problem
Hi, I have a problem with a Cyclone III design which uses two 512byte Fifos. The problem is that the design is working fine, and after changing sth. e.g. adding some signals to signal tab, t...
19 years ago --- Quote Start --- tan defaults to cutting timing between unrelated clocks. --dalon --- Quote End --- what do you mean with "tan defaults"? --- Quote Start --- in signaltap, use 2 capture windows, one for each clock. you could easily be seeing eroneous errors. --- Quote End --- I know that it is not good to sample a signal with another clock domain, but I think that it is not a clock domain problem because I handle data all-around from one fifo to another and I should get the right data also on the 125 clock domain (FIFO 2) wich should be OK in Signal Tab. ----->DATA--->|_FIFO_1__________|---->DATA---->|__FIFO_2_________|---> DATA _____125Mhz___===============_____33Mhz___================ ___125Mhz regards Cyclone
