19 years agoCyclone III FIFO problem
Hi, I have a problem with a Cyclone III design which uses two 512byte Fifos. The problem is that the design is working fine, and after changing sth. e.g. adding some signals to signal tab, t...
19 years agotan defaults to cutting timing between unrelated clocks.
in signaltap, use 2 capture windows, one for each clock. you could easily be seeing eroneous errors. --dalon
