15 years agocyclone iii epcs, software fail to boot
hi, The design is cyclone iii 3c55 with EPCS128. There is epcs controller in NIOS design. The sof and elf is ok when i use "run as hardware". But the software did not automatic load when power-...
15 years agoHi,
I have almost the same problem. Does your software start if you do: nios2-flash-programmer --epcs --base=0x21000 --go after power up? This will poke my software into starting, but I can't get it to start automatically at power up. Mark.
