16 years agoCyclone III EP3C25 High Temperature Booting Problem
Dear Friends, I am facing a high temperature booting problem with EP3C25F324. I found that the FPGA can not boot up at temperature over 40 Centigrade while doing the temperature cycling tests....
16 years agoYou should be able to further trace down the configuration process. Does the EPCS read start, is it possibly aborted, because the FPGA means to detect a CRC error? What do you see at the CONF_DONE and nSTATUS pins?
Generally I see mainly three possible causes for configuration failure: - FPGA isn't coming out of reset - wrong level of configration related pins, e.g. due to leakage currents - configuration data are considered invalid P.S.: Also a bad solder joint or broken PCB with temperature dependant behaviour may be an explanation
